It is currently Tue Aug 12, 2025 7:43 am
PostPosted: Sun Feb 07, 2016 2:31 pm
Last Name: Beaver
City: Lake Forest
I am getting ready to do my first beveled arm rest and I have a couple of questions regarding the veneer portion.
How do you apply the veneer? Glue on both surfaces, dry, then iron on? Wet glue up? If so how do you clamp?
What glue do you use?
Thanks for your replies!!!
Joe Beaver
Maker of Sawdust
PostPosted: Sun Feb 07, 2016 3:02 pm
Last Name: Ensor
City: Springfield
State: Missouri
Fish glue on guitar side (have also used TB1), wood veneer at .020" thickness shouldn't need bending or ironing, tape from middle to one point at about 1.5" intervals then from middle to other point, once happy with layout, tape the heck out of it. In fact, I go back with the rubber bands I use to do binding and then cover the whole area with those too.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Sun Feb 07, 2016 3:37 pm
Last Name: Beaver
City: Lake Forest
Thanks Chris,
I have yet to use fish glue but I assume you had similar results with the same method with titebond 1?
Joe Beaver
Maker of Sawdust
PostPosted: Sun Feb 07, 2016 9:02 pm
Last Name: Ensor
City: Springfield
State: Missouri
Similar results, but fish allows you to touch it up if it didn't turn out perfect on the first try.
PostPosted: Sun Feb 07, 2016 10:59 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I use the iron on method. Works great. Regular tite bond. Let both surfaces dry to clear tack (~30 min) Then iron on.
PostPosted: Mon Feb 08, 2016 8:07 pm
First name: Danny
Last Name: Vincent
TB1 on the guitar and a little on the veneer at the 2 tips. Then tape the crap out of it.
PostPosted: Tue Feb 09, 2016 12:00 am
Last Name: Beaver
City: Lake Forest
Interesting. I've never done the iron on veneer thing but im thinking it might be worth a try. When I read on the Veneer Supplies website they say the glue they offer is better for the job. I think it is called heatlock.
Anyone have experience with it?
Joe Beaver
Maker of Sawdust
PostPosted: Tue Feb 09, 2016 8:01 am
Last Name: O'Melia
City: Huntsville
State: Alabama
All I can add is the TB1 iron on is a one shot deal. Screw it up, sand it off.
PostPosted: Tue Feb 09, 2016 12:10 pm
Last Name: Beaver
City: Lake Forest
Mike,
that's what heat lock says about theirs also. They must be very close to the same. Probably either one will do the job.
Joe Beaver
Maker of Sawdust
